disable cli scripting output
Description
Disables the display of CLI commands and responses during script operation.
Syntax Description
Default
During interactive script sessions: CLI scripting output enabled.
During load script command operation: CLI scripting output disabled.
Usage Guidelines
When the CLI scripting output is disabled, the only script output displayed is the show var {varname} command and its output. All other commands and responses are not displayed.
When the load script filename {arg1} {arg2} ... {arg9} command is entered, the software disables CLI scripting output until the script is complete, and then CLI scripting output is enabled. Use the enable cli scripting output and disable cli scripting output commands to control what a script displays when you are troubleshooting.
The following command disables CLI scripting output for the current session or until the enable cli scripting output command is entered:
This command was first available in ExtremeXOS 12.1.2.
Platform Availability
